sg300 strange running-config
Mary Poppins
dear all,
In my sg300 switch I configured the gi port as trunk:
switchport mode trunk
switchport trunk allowed vlan add 1
no spanning-tree portfast
no spanning-tree bpduguard
however the 'trunk allowed vla add 1' line generate error, i think because vlan 1 is the default, when i check the port it shows trunk, and it is operate well.
But wehen i show running-config it shows only this:
interface gigabitethernet1
Why is the switchport mode trunk and the trunk allowed commands missing in the running-config? However I have another trunk port with allowed vlan 1,3, that is included partly in the running-config, but there is no switchport mode trunk
interface gigabitethernet52
 spanning-tree port-priority 16
 switchport trunk allowed vlan add 3
Is the trunk the base config, so it is left by default?
thank you
devils_advocate
Level 7
Level 7
Dynamic Desirable is the default.
Effectively the switch will negotiate with whatever the port is plugged into.
If the other side is a Trunk, it will form a Trunk
If the other side is an Access Port, they will both be an access port.
Vlan 1 is the Native and default vlan, therefore is always allowed on the Trunk, hence why it does not show up in the running config.
The running config will only show commands which are not the default.
I suspect whatever port interface gigabitethernet52 is plugged into on the other end, the config will be a Trunk because the default is to negotiate.
devils_advocate
Level 7
Level 7
Thank you for your answer, however I can't find any dtp or dynamic desirable commands in the switch sg330-52, neither in its manual. So I think the switch cannot be configured in that way. Or where can I find this command? At the interface's switchport section? In addition I issued the 'switchport mode trunk' on the trunk ports.
Eric Reyes
It would be great if you "copy and paste" here the errors that generate the commands that you introduce,  sometimes they  point to the solution.
