sh interface gi1/0/1, packet count does not increment but bytes count do ?
vk1001111
Hi!
Im experiencing some hangs on a network connected camera, camera is powered over PoE...
The camera is not that important.
here is an example of sh interface for that port
switch#sh int gi1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  Description: XXXXXXXXXX
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     7722720 packets input, 696305190 bytes, 0 no buffer
     Received 18 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     26156156 packets output, 2546644106 bytes, 0 underruns
After a hang the 'packets input' counter stays at the same, i can´t see a MAC-adress associated with the port...
But the byte count continues to increment with about 6 bytes/15 min interval.
How is this possible since i never see a MAC-adress on that port ? And what traffic could it be ?
Thank you!
rsimoni
if something is connected  to that (as it should be as per outouts)  port the traffic you might expected is some type of L2 PDUs (STP, CDP, etc.).
Riccardo
rsimoni
Riccardo
Thank you for your answer.
I will mark this thread as answered, if someone has a better explanation (or confirmation of Riccardos answer) that would be appreciated.
Thank you Riccardo!
