SHDSL Bonding
t4tauseef33
what are the mechanisms to bond the 2 SDSL lines as a one link on the cisco routers like 2800?
Is the bonding service is dependent on teh ISP?
Giuseppe Larosa
Hello Tauseef,
multilink PPP over ATM can be a solution because you have probably an ATM interface over SDSL.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800b6098.shtml
this requires cooperation with the provider
otherwise you can use the two links as two parallel L3 links.
It depends on your needs.
Hope to help
Giuseppe
