Simple question about QOS
from88
Level 6
Level 6
Hello guys,
If i configure the "mls qos trust" command. The devicestrusts the incoming qos values. But this is it ? Or i should create policy maps with classmaps to match the appropriate (COS or DSCP) values to get the qos working ?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained  within this   posting without consideration and with the reader's  understanding that   there's no implied or expressed suitability or  fitness for any  purpose.  Information provided is for informational  purposes only and  should not  be construed as rendering professional  advice of any kind.  Usage of this  posting's information is solely at  reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Most (all?) Cisco switch have some sort of default QoS policy when it's enabled.  The default often is very, very basic.  Whether such a default is suitable for you would you require comparing what's it doing to your needs.
Also, later Cisco switches have some sort of AutoQoS command that provides a common or best practice implementation QoS policy.  This too, if supported and enabled, should be compared to your needs.
For example, when you enable just QoS you might go from one output queue to multiple queues on an egress port, but each with some simple bandwidth sharing.  AutoQoS might enable one queue as a priority queue and "tweak" queue bandwidth allocations, drop policies and how frames/packets are directed to the queues.
All of the above is a long way of say, probably not, to "But this is it?".  However, you also may not need to define policy maps and class maps, etc.
Joseph W. Doherty
Disclaimer
Posting
