simple question what does fa 0/1 mean?
Ciscobeginner1
on a cisco switch ethernet interface fa 0/1  mean
fa means fast ethernet
1  means interface 1
what does 0 mean?
Reza Sharifi
0/1 0 is the module number and 1 is the port number. HTH
0 Means the first switch.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally, if you have just two numbers, separated by a slash, it's as Reza notes.
If you get into 3 numbers, separated by slashes, the first digit would be a switch number in a stack or VSS pair, second digit module, and 3rd digit port.
