Simple VLAN question (two devices, diff vlans)
billmatthews
I have two different 3750s, each is just a stand alone lab switch (no connections to each other).  I have a test network on switch1 (vlan10) that is 10.10.10.0/24.  The same network (10.10.10.0/24) exists on switch2 as vlan 101.
I need to connect the two networks together.  I don't want to use trunks, or change the vlans on each switch.  Can I have two ports in access mode in different vlans, connected via a crossover cable?
So on switch1 I would have an access port in vlan10 connected via crossover to an access port in vlan101 on switch2?
lgijssel
Level 9
Level 9
Yes, this would work. I could add a lot of if's and but's and this type of solution is certainly not recommended for ease of administration but bottomline is that it will work. So that's easy answer.
regards,
Leo
