slm and CISCO catalyst
ciscocips
Hello gurus.
I need to create a 802.1q trunk between a CISCO Catalyst and a CISCO SLM224G switch.
No problem for the IOS switch, but I don't have clear how should I create a trunk with the web interface of the SLM224. The docs are not explaining anything on this.
Anyone of you can help? Thanks so much....
Cips
Reza Sharifi
Hi Cips,
According to the admin guide it is under vlan management>port setting> then click on acceptable frame type then you see tagged or untagged.
Here is the admin guide:
http://www.cisco.com/en/US/docs/switches/lan/csbss/slm2024/administration/guide/SLM_Admin_Guide_Publish.pdf
Good luck
Reza
