SNMP help
j.mccartney
We suddenly started getting a rash of alerts from our monitoring tool (OpManager) today and can't figure out why we are getting them. We were getting alerts for our ASA5500's first then it was showing up on some of our 1841 routers. We are getting AuthenticationFailure messages, an attachment shows the error.
I'm wondering why it alerrts on system uptime??? What should I be checking, I'm not too familiar with interpreting these errors.
Thanks.
5 Replies 5
Reza Sharifi
No attachment.
If you are getting authentication failure check to see if any one has made any changes to the ACS server.
Reza
Hi Reza,
We are using Radius.
John
Hi John,
The attached document is too small to read.
Since you have multiple devices complaining about authentication failure, I would check the Radius logs to see if any one has changed anything.
Reza
j.mccartney
Let me see if the attachment works this time, thanks again for helping.
Do the routers have "snmp-server trap authentication" in their config?  The ASAs would use "snmp-server enable traps snmp authentication"
