%SPANTREE_VLAN_SW-2-MAX_INSTANCE
mahesh18
Level 6
Level 6
                   Hi Everyone,
On 3550 switch i see logs below
%SPANTREE_VLAN_SW-2-MAX_INSTANCE: Platform limit of 128 STP instances exceeded. No instance created for VLAN95 (port Gi0/1).
Need to  know what does this log mean?
Mahesh
2 Accepted Solutions
Rolf Fischer
Level 9
Level 9
Hi Mahesh,
there's a platform limitation of  max 128 Spanning-Tree instances for the 2k and 3k platforms.
When you create more than 128 VLANs (e.g. on a 4k or 6k which is the VTP server), the new VLANs are created but there is no spanning-tree instance for this VLANs on those platforms. Without manual pruning the uplink-ports (switchport trunk allowed vlan ) there's a serious risk of a bridging-loop!
System Message Guide
Best Regards
Rolf
Here are two similar discussions which give very detailed explanation:
https://supportforums.cisco.com/thread/2132702
https://supportforums.cisco.com/thread/2047402
Hope that helps
Rolf
Rolf Fischer
Level 9
Level 9
Hi Mahesh,
Best Regards
Rolf
Hope that helps
Rolf
