Static Routing with VLANs and VRFs
Ben Squire
I'm preparing to deploy a new WLAN setup across a few locations, where each location has the same SSIDs and those networks are isolated from the rest of the production network.  I set up a lab environment to learn VRF (well, VRF-Lite, I suppose).  I have a attached a basic network diagram.  At this point, I'm mainly concerned with the right side of the picture.  I have two VLANs that should be isolated from each other and the rest of the network, but they both need to connect to a DHCP server in a third VLAN, which will give out addresses from different pools to each one.  So, how can I route traffic from VLANs 500 and 501 to VLAN 505 in the HQ router?  I tried rd and route-target statements in the VRFs, but it hasn't worked so far.  Also, my next step will be to get traffic coming from the branch to VLAN 505, also.  So, if it can be done in the VRF, that would probably be simplest in the long run.
So, the succinct version:  In the HQ router, how to route traffic between Host A and the DHCP server?
Any ideas?  Thanks in advance.
5 Replies 5
in order to isolate inter-Vlan traffic and still allow DHCP requests, use an extended access list. Post the configs of your routers so we can help you with the access list...
Thanks, Georg.
HQ Router:
Current configuration : 2801 bytes
! Last configuration change at 19:22:05 UTC Tue Jul 17 2018
! NVRAM config last updated at 19:22:06 UTC Tue Jul 17 2018
version 15.1
hostname hq-r
boot-start-marker
boot-end-marker
vrf definition VRF_500
description VRF_500
rd 1234:500
route-target export 1234:500
route-target import 1234:505
address-family ipv4
exit-address-family
vrf definition VRF_501
rd 1234:501
route-target export 1234:501
address-family ipv4
exit-address-family
vrf definition VRF_505
rd 1234:505
route-target export 1234:505
route-target import 1234:500
route-target import 1234:501
address-family ipv4
exit-address-family
enable secret 5
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid
license boot module c2900 technology-package securityk9
redundancy
interface GigabitEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.500
vrf forwarding VRF_500
encapsulation dot1Q 500
ip address 172.16.0.1 255.255.255.0
interface GigabitEthernet0/0.501
vrf forwarding VRF_501
encapsulation dot1Q 501
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/1
ip address 10.10.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.500
ip address 192.168.0.50 255.255.255.0
ip helper-address 192.168.5.2
interface GigabitEthernet0/1.501
ip address 192.168.1.50 255.255.255.0
interface GigabitEthernet0/1.505
vrf forwarding VRF_505
encapsulation dot1Q 505
ip address 192.168.5.50 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
shutdown
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
interface GigabitEthernet0/1/4
shutdown
interface GigabitEthernet0/1/5
shutdown
interface GigabitEthernet0/1/6
shutdown
interface GigabitEthernet0/1/7
shutdown
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
logging esm config
control-plane
line con 0
line aux 0
line vty 0 4
password adm
login
transport input all
scheduler allocate 20000 1000
end
Branch Router:
Current configuration : 3362 bytes
! Last configuration change at 19:31:56 UTC Tue Jul 17 2018
! NVRAM config last updated at 19:31:58 UTC Tue Jul 17 2018
version 15.1
hostname branch-r
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv4
exit-address-family
enable secret 5
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 10.0.0.2 255.255.255.0
duplex auto
speed auto
no mop enabled
ip address 172.16.0.2 255.255.255.0
ip address 172.16.1.2 255.255.255.0
ip address 10.20.0.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.100.50 255.255.255.0
ip address 192.168.101.50 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface GigabitEthernet0/3/0
no ip address
shutdown
interface GigabitEthernet0/3/1
no ip address
shutdown
interface GigabitEthernet0/3/2
no ip address
shutdown
interface GigabitEthernet0/3/3
no ip address
shutdown
interface GigabitEthernet0/3/4
no ip address
shutdown
interface GigabitEthernet0/3/5
no ip address
shutdown
interface GigabitEthernet0/3/6
no ip address
shutdown
interface GigabitEthernet0/3/7
no ip address
shutdown
interface Vlan1
no ip address
shutdown
no ip http server
ip route vrf VRF_500 192.168.0.0 255.255.255.0 172.16.0.1
ip route vrf VRF_500 192.168.5.0 255.255.255.0 172.126.0.1
ip route vrf VRF_501 192.168.1.0 255.255.255.0 172.126.1.1
ip route vrf VRF_501 192.168.5.0 255.255.255.0 172.126.1.1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password adm
login
transport input all
end
the below isolates your VLANs from each other and also the rest of your network. You also do not have any outside (Internet) connectivity when you apply this access list, is this what you want ? All the clients have access to is the DHCP server:
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 host 192.168.5.2
access-list 101 permit ip host 192.168.5.2 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 host 192.168.5.2
access-list 101 permit ip host 192.168.5.2 192.168.1.0 0.0.0.255
duplex auto
speed auto
ip access-group 101 in
Thank you, Georg.
I haven't worked much with networking for quite some time and I'm pretty rusty.  Right now, I'm just trying to understand connecting the VLANs and VRFs through the network while isolating them.
I created the access-list you suggested and applied it to the two interfaces, but I still can't ping between the hosts in VLANs 500 and 501 and the DHCP server in VLAN 505.  Is permitting the traffic enough, or do I need to add some kind of routing between the VRFs and/or VLANs?
-Ben
HQ Router:
int lo0
ip address 1.1.1.1 255.255.255.255
router bgp 6500
address-family ipv4 vrf RF_500
redistribute connected
redistribute static
address-family ipv4 vrf RF_501
redistribute static
address-family ipv4 vrf RF_505
redistribute static
