Strange cycled values in "Total output drops"
alex
Hello!
I found strange cycle in values "Total output drops" on one of 3750 GE ports (ios c3750-advipservicesk9-mz.122-40.SE).
Values goes in next cycle: 0, 407, 814, 4294966889. But the port/controller/cable have no any physical or logical errors.
Port connected to server with ethernet card Intel(R) PRO/1000 EB Network Connection with I/O Acceleration.
From server side - no errors/drops/etc.
Port configuration:
interface GigabitEthernet2/0/9
description * it-hrk1-1 *
switchport access vlan 11
switchport mode access
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
Sample output of switch port statistics:
GigabitEthernet2/0/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0018.ba11.6c89 (bia 0018.ba11.6c89)
Description: * it-hrk1-1 *
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:08, output hang never
Last clearing of "show interface" counters 00:07:16
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294966482
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 2 packets/sec
5 minute output rate 133000 bits/sec, 62 packets/sec
4270 packets input, 336781 bytes, 0 no buffer
Received 15 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
33299 packets output, 8137577 bytes, 0 underruns
This cycle present at only one port. On the other ports connected servers with same ethernet cards.
Does anyone have idea what it can be? And why?
tstanik
Level 5
Level 5
Total output drops field in the show interfaces privileged EXEC command output displays ASIC drops. On some interfaces, the Total output drops field is always 0 even though the show platform port-asic stats drop privileged EXEC command output shows ASIC drops. The Total output drops value is the same for all the ports that are linked to the same ASIC.
