Streaming problems with my new Cisco 871w
manasesramos
     Would you know why when streaming from my Cisco 871w router I get disconnected a lot? well all the time, for example when im listening to the radio it disconnects from the station for like a minute then it reconnects for like another minute and it disconnects again, this happens if im connected hard wired or wireless, and when im watching youtube it loads only half way and it will only play half the video then it will sit there like its buffering.
I just started studying for my CCNA and it has not been easy plus all this problems im having its taking the fun out of it.
Any help you may give me will be very appreciated.
MR.
manasesramos
MR-r1#sh running-config
Building configuration...
Current configuration : 3771 bytes
version 12.4
no service pad
hostname MR-r1
boot-start-marker
boot-end-marker
enable secret 5 *****************************
no aaa new-model
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3978252741
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3978252741
revocation-check none
rsakeypair TP-self-signed-3978252741
crypto pki certificate chain TP-self-signed-3978252741
certificate self-signed 01
  30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393738 32353237 3431301E 170D3039 30353137 32303132
  34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373832
  35323734 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A714 4768AEC6 0159075F 4CF946EC 10F621A6 45C0886D D090DEB4 73284CDF
  4C544F2F D9408651 37CDCF20 61B4CAD0 93C8DA4A FB0D88F5 7CB69AA9 4B92E894
  A42DBA06 CDD77233 FCBAEAA9 35CE645B CE3CEFD0 9F078E7F B96607B4 B73C71FA
  CC55E90F FC354C00 9A42AC5E 2FD6CA36 D3EF9AC5 411D4193 380E4393 7D641E18
  345F0203 010001A3 70306E30 0F060355 1D130101 FF040530 030101FF 301B0603
  551D1104 14301282 104D522D 72312E4D 522D6C61 622E636F 6D301F06 03551D23
  04183016 80140CCC 4819CF1C 5333CAD0 AD9B9899 ECBF2825 3881301D 0603551D
  0E041604 140CCC48 19CF1C53 33CAD0AD 9B9899EC BF282538 81300D06 092A8648
  86F70D01 01040500 03818100 4808A6A5 9BEB21F7 D31104DE C6B5B43F A294B41E
  3050D572 8B0AFF95 AA1A41A4 FE8E2966 2C66B955 328A15C4 FB1677EB 50BD6187
  C22491EC CCCC2BFC F651444B B350B10E F7ABE2F3 5C31A599 CA367F2D 75DFB8D8
  5467E128 DEAF53E6 04E76940 8E107DC3 0696CBA6 7FC55D63 AF161713 6077D202
  A238EB39 B8B3F0A7 8431D05B
        quit
dot11 syslog
dot11 ssid RamFam
   authentication open
   guest-mode
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.50.25.1 10.50.25.9
ip dhcp excluded-address 10.50.25.51 10.50.25.254
ip dhcp pool sdm-pool1
   import all
   network 10.50.25.0 255.255.255.0
   domain-name MR-lab.com
   default-router 10.50.25.1
   dns-server 10.50.25.1 10.55.55.1
ip domain name MR-lab.com
ip name-server 10.50.25.1
ip name-server 10.55.55.1
username ram*** privilege 15 secret 5 *******************************
archive
log config
  hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description Internet WAN Port
ip address dhcp
speed 100
full-duplex
interface Dot11Radio0
ip address 10.50.55.1 255.255.255.0
shutdown
encryption key 1 size 128bit 0 AB2081CA12B126DD2F95ABCF32 transmit-key
encryption mode wep mandatory
ssid RamFam
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
description $ES_LAN$
ip address 10.50.25.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
password *********
logging synchronous
login
no modem enable
line aux 0
line vty 0 4
password ***************
logging synchronous
login local
scheduler max-task-time 5000
end
MR-r1#
MR-r1#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T7, RE                                             LEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Aug-08 07:43 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
MR-r1 uptime is 21 hours, 8 minutes
System image file is "flash:c870-advsecurityk9-mz.124-15.T7.bin"
