Supervisor card restart itself on Catalyst 6509E please help!!
teethawat.r
     Supervisor card restart itself on Catalyst 6509E please help me find root cause.Below are information, If you need more please let me know thanks.
Product Number: WS-C6509E-S32-GE
Description: Cisco Catalyst 6509E, WS-SUP32-GE-3B, Fan Tray (req. P/S)
here is last log before forced restart.
xxx#sh tech
Jul 26 15:31:24.788 UTC: %CPU_MONITOR-3-PEER_EXCEPTION: CPU_MONITOR peer has failed due to exception , reset by [5/0]
%Software-forced reload
17:31:24 CEST Fri Jul 26 2013: Breakpoint exception, CPU signal 23, PC = 0x420035B0
xxx#sh ver
Cisco IOS Software, s3223_rp Software (s3223_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 16-Jan-08 19:09 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
xxx uptime is 4 days, 13 hours, 1 minute
Uptime for this control processor is 4 days, 13 hours, 1 minute
Time since xxx switched to active is 4 days, 13 hours, 0 minutes
System returned to ROM by s/w reset at 14:51:34 BKK Tue Apr 14 2009 (SP by processor memory parity error at PC 0x40AC7378, address 0x0)
System restarted at 17:34:12 CEST Fri Jul 26 2013
System image file is "bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXH1.bin"
7 Replies 7
Vignesh Rajendran Praveen
Kindly provide me the below requested information for me to assist you further.
1) Show log from the device
2) Crashinfo file
3) Show module
Thanks & Regards,
Vignesh R P
Hi Vignesh
     As attached.
Best regards,
Thanks a lot for the outputs. Also kindly do provide the output of dir from the device.
T & R,
Vignesh R P
Kindly check if there is a crashinfo file in the location sup-bootdisk: . If yes, then kindly do provide that crashinfo file too.
T & R,
Vignesh R P
Leo Laohoo
Software-caused crash.
Hi Leo,
The one that you are referring to has happened on the 14th of April 2009. I believe help is required to understand the reason behind the crash that took place on 26th July, 2013.
T & R,
Vignesh R P
LOL!
Good point.
