Support for 1 Gig connection on the SUP8-E module.
Folks,
I wanted to check if we can plug in GLC-SX-MM modules on the SUP-8 E? The release notes I read mention that we can use them on the SUP8-E but when I look at the sh ip int brief output from the switch this does not mention any 1G interfaces.
in short will the SUP8E support 1 Gig uplink interfaces?
TenGigabitEthernet5/1  unassigned      YES manual up                    up
TenGigabitEthernet5/2  unassigned      YES unset  up                    up
TenGigabitEthernet5/3  unassigned      YES unset  administratively down down
TenGigabitEthernet5/4  unassigned      YES unset  administratively down down
TenGigabitEthernet5/5  unassigned      YES unset  administratively down down
TenGigabitEthernet5/6  unassigned      YES unset  administratively down down
TenGigabitEthernet5/7  unassigned      YES unset  administratively down down
TenGigabitEthernet5/8  unassigned      YES unset  administratively down down
TenGigabitEthernet6/1  unassigned      YES manual up                    up
TenGigabitEthernet6/2  unassigned      YES unset  up                    up
TenGigabitEthernet6/3  unassigned      YES unset  administratively down down
TenGigabitEthernet6/4  unassigned      YES unset  administratively down down
TenGigabitEthernet6/5  unassigned      YES unset  administratively down down
TenGigabitEthernet6/6  unassigned      YES unset  administratively down down
TenGigabitEthernet6/7  unassigned      YES unset  administratively down down
TenGigabitEthernet6/8  unassigned      YES unset  administratively down down
N.
If the command is not present then the IOS should be able to auto-detect the SFP/SFP+ used.
6 Replies 6
Leo Laohoo
Use the command "hw-module uplink select ?" to choose your uplink
I am not able to get this feature. I am running version .03.03.01.XO.151-1.
I hope that is not a problem.
sw-edge-ind-pun4-b1f(config)#hw-module ?
  module  Specify a linecard slot for the hw-module command
  slot    Specify a linecard slot for the hw-module command
  system  Specify the system parameter
I only want to bring specific ports on 1 Gig.
The SUP8-E shows the active LED on ports 1-4 as active and does not show any LED on ports 5-8.
I was using 5/5 for all the testing now. As soon as I inserted the SFP in 5/3 it shows me the light and shows the BW on the port as 1000Mbps. :-)
Now, how do I also get the ports 5-8 as active?
N.
This has been resolved. The auto detect worked.
Thanks for taking the time to rate our posts.  :)
