Switch 3750X-48T-L question
360rundll
------------------ show inventory ------------------
NAME: "1", DESCR: "WS-C3750X-48"
PID: WS-C3750X-48T-L , VID: V06 , SN: FDO1817Z3L1
NAME: "Switch 1 - Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC , VID: V03D , SN: DCB18129321
NAME: "Switch 1 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 1G Module"
PID: C3KX-NM-1G , VID: V01 , SN: FDO19140J11
NAME: "GigabitEthernet1/1/1", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: AGJ2019R2T1
NAME: "GigabitEthernet1/1/2", DESCR: "1000BaseSX SFP"
NAME: "GigabitEthernet1/1/3", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: AGJ2019R1H1
NAME: "GigabitEthernet1/1/4", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: AGJ2019R1B1
------------------ show version ------------------
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 22:53 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
CHofficeSW01 uptime is 7 weeks, 2 hours, 33 minutes
System restarted at 12:06:22 GMT Thu Oct 20 2016
System image file is "flash:c3750e-universalk9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1817Z3LE
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 50:87:89:A9:CA:00
Motherboard assembly number : 73-12552-11
Motherboard serial number : FDO181800P1
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3750X-48T-L
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO18171J61
System serial number : FDO1817Z3L1
Top Assembly Part Number : 800-31326-09
Top Assembly Revision Number : B0
Version ID : V06
CLEI Code Number : CMMPN00DR1
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750X-48 15.0(2)SE8 C3750E-UNIVERSALK9-M
Configuration register is 0xF
------------------ show env all ------------------
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
SYSTEM TEMPERATURE is OK
System Temperature Value: 26 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-350WAC DCB18129321 OK Good Good 350/0
1B Not Present
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
Hi,  all
       From the log, FAN 2 is really OK?  Just it is not present, what is "FAN PS-2" meaning? I don't know very well. Who can solve my question?
BR.
Mark Malone
You only have 1 power supply so there is no issue here tahts the correct alarm
1B Not Present
Tausif Gaddi
The switch operates with either one or two active power supply modules or with power supplied by an expandable power supply, XPS 2200. A Catalyst 3750-X switch that is part of a StackPower stack operates with power supplied by other stack switches.
You can use two AC modules, two DC modules, one AC and one DC module, or one module and a blank cover.
All power supply modules have internal fans. All switches ship with a blank cover in the second power supply slot.
