switch based show interface gi0/X pause inputs
jledwardsr
Level 3
Level 3
I have never seen a pause input on any of my Cisco devices. I am working with a new third party hardware and I am seeing these occur. Anyone know what pause inputs mean or how Cisco defines them. I can't find anything related to them online.
SW1_MDF#sh int gi0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0023.ea5d.fb1a (bia 0023.ea5d.fb1a)
Description: DSL2_MDF
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
6103271 packets input, 1515380005 bytes, 0 no buffer
Received 132253 broadcasts (0 multicasts)
0 watchdog, 16167 multicast, 460 pause input
12667143 packets output, 6917415658 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Giuseppe Larosa
Hello Jermaine,
this is not a problem by itself
IEEE pause frames are sent by the device connected to the switch port in an effort to slow down sending rate of switch port.
each pause frame would ask for a little silence time interval (the equivalent of 512 bytes sent on wire)
see
http://en.wikipedia.org/wiki/Ethernet_flow_control
but you have :
input flow control is off so your switch port should ignore these messages.
you may consider to enable it because the other device can be dropping frames from time to time for lack of buffers.
Hope to help
Giuseppe
"you may consider to enable it because the other device can be dropping frames from time to time for lack of buffers. "
BTW, generally, best practice would be to not enable it between network devices.
