Switch ME1200 Boot Issue
zakariaa azzouz
Hi ,
I have a problem with switch cisco ME1200 ,It 's can't boot correctly .
This is the boot process message :
M25PXX : Init device with JEDEC ID 0x20BA19.
Sandino ME1200 board detected (VSC7418 Rev. B).
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version 1_11_Cisco - built 09:17:44, Mar  7 2014
Copyright (C) 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009
Free Software Foundation, Inc.
RedBoot is free software, covered by the eCos license, derived from the
GNU General Public License. You are welcome to change it and/or distribute
copies of it under certain conditions. Under the license terms, RedBoot's
source code and full license terms must have been made available to you.
Redboot comes with ABSOLUTELY NO WARRANTY.
Platform: SANDINO (MIPS32 24KEc) SERVAL
RAM: 0x80000000-0xa0000000 [0x800224a0-0x9ffdfffc available]
FLASH: 0x40000000-0x41ffffff, 512 x 0x10000 blocks
FLASH: 0x42000000-0x43ffffff, 512 x 0x10000 blocks
== Executing boot script in 3.000 seconds - enter ^C to abort
RedBoot> diag -p
RedBoot> fis load -d managed
Image loaded from 0x80040000-0x812f23c8
RedBoot> go
No PIC update needed.
W cisco_init 00:00:00 1/cisco_init#62: Warning: Cisco init Entered
POST is disabled
W cisco_init 00:00:00 32/cisco_init#66: Warning: Cisco init Start
Press ENTER to get startedW cisco_init 00:00:01 32/cisco_init#72: Warning: MASTER_UP
W cisco_init 00:00:02 32/cisco_init#78: Warning: SWITCH_ADD, isid: 1
 icli read failed
- Can anyone help .
Leo Laohoo
Sounds like the config-registry is programmed to boot into ROMmon.
Hi Leo ,
Thanks for your reply , I want to know how i can change the config registry for the switch boot correctly .
Thanks & Regards
Hi ,
Correct config-register value is 0x2102 . you can use below command to configure the register value.
Router#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#config
Router(config)#config-register 0x2102
you can refer below links for more details.
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
VS.Suresh.
*Plz rate the usefull posts *
