Switch / Network troubleshooting
Matt01607
Visitor
Hi all, im currently a student studying a cert 4 in Cybersecurity and im on my final assessment.
My issue is that even with all these configurations being correct, PC A cannot ping past the Switch and PC B cannot even ping the default gateway, i've double checked the interfaces on the routers and verified that they are correct. I'm currently at a loss for what's gone wrong. Even the switch Vlan 1 interface is correct and the status reads as UP.
the assessment topology is attached.
EDIT 1: PC A is a kali linux machine, and this work is done on an online VM service provided by my institution.
also, the switch on this network is actually a router but it is to be treated as a switch for the purpose of the assingment, as such it has been configured beforehand to be configured like a switch by the insitution.
6 Replies 6
Georg Pauwen
post the full running configurations of the switches, the routers, and the output of 'ipconfig /all (or something similar) of both PCs.
Hi there, the work is done on a online VM machine service which resets everytime i schedule a lab, i can currently provide the scripts i used to automatically configure the routers and switch however. i'll get the outputs for you soon.
S1
enable
configure t
hostname S10062492
Interface vlan1
ip address 192.168.32.13 255.255.255.240
no shutdown
exit
no ip routing
ip default-gateway 192.168.32.14
exit
enable secret Cybersecurity
line con 0
password VU21988pass
exit
line vty 0 20
password Telnetpass
exit
interface range gigabitEthernet 0/0-3
shutdown
exit
interface range gigabitEthernet 1/0-3
shutdown
exit
interface range gigabitEthernet 2/0-1
shutdown
exit
line con 0
exec-timeout 0
exit
Login block-for 30 attempts 3 within 130
R1
enable
config t
no ip domain-lookup
hostname R10062492
ip domain-name BHIcyber.com
line con 0
exit
line vty 0 20
password Telnetpass
exit
security passwords min-length 10
username admin priv 15 password admin1pass
line VTY 0 20
login local
transport input telnet ssh
exit
service password-encryption
banner motd #Authorized users only#
interface gigabitEthernet 1
description interfaceGig1
ip add 192.168.32.22 255.255.255.248
no shutdown
exit
interface gigabitEthernet 2
description interfaceGig2
ip add 209.165.200.2 255.255.255.252
no shutdown
exit
crypto key generate rsa
1024
R2
enable
config t
no ip domain-lookup
hostname R10062492
line con 0
exit
line vty 0 20
password Telnetpass
exit
line VTY 0 20
login local
exit
ip add 209.165.200.1 255.255.255.252
no shutdown
exit
ip add 192.168.32.14 255.255.255.248
no shutdown
exit
1024
I don't see any routing on either router. Add the static routes below:
R1
ip route 192.168.32.8 255.255.255.248 209.165.200.2
R2
ip route 192.168.32.16 255.255.255.248 209.165.200.1
Hi George, i forgot to mention i absolutely suck at networking so i'm not familiar with these commands, should i issue this in the #(config)
setting, or the line con 0 setting??
Hello
Do you have any access-list policy applied anywhere if not then depending if you have all the confiuration correctly make sure ip routing  is disabled on the switch and you dont have any software FW enabled on the PC's that would negate ping?
Kind Regards
Paul
HI there, yes as part of the assingment student information we were told to issue a no ip routing command, as far as i'm concerned the PC's all have their relative firewall settings turned off
