Switch port is broken
c.akbas01
Hello
The radiolink device attached to the switch port is broken. The port where the radiolink device is plugged in is broken and the mercy lights are on when the port is empty. And this port does not work around the ports. We rebooted the switch but the problem was not resolved. We can not use these ports. What is the problem? Could you help?
which devices do you have (platform, e.g. Cisco 2960 switch) ?
6 Replies 6
platform SG500X-24 24-Port Gigabit
with 4-Port 10-Gigabit Stackable Managed Switch
is the SG500 a PoE (Power over Ethernet) switch ? Can you post the running config ?
No poe
I do not think I'm interested in configuration, but this. running config
vlan database
vlan 100,110,120,200
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
port-channel load-balance src-dst-mac-ip
bonjour interface range vlan 1
hostname TOKI-CISCO24SWITCH
logging origin-id ip
username f-admin password encrypted 593551cbe4a5923ee7da259cbec94bdc2604c6ae privilege 15
username f-recovery password encrypted 9440968f81b9bd25620dd635ede5d1fa8c1b624b privilege 15
ip ssh server
snmp-server location "TOKI KULE"
snmp-server contact "CETIN AKBAS"
clock timezone " " 3
interface vlan 1
 ip address 10.99.100.12 255.255.0.0
 no ip address dhcp
interface vlan 100
 name Management
 ip address 172.16.100.12 255.255.0.0
interface vlan 110
 name Internet
 ip address 10.34.100.12 255.255.0.0
interface vlan 120
 name Cloud
 ip address 10.16.100.12 255.255.0.0
interface vlan 200
 name Kamera
 ip address 192.168.1.12 255.255.255.0
interface gigabitethernet1/1/1
 rate-limit 30720 512000
 traffic-shape 61440 512000
 switchport trunk allowed vlan add 100,110,120,200
interface gigabitethernet1/1/3
interface gigabitethernet1/1/4
interface gigabitethernet1/1/5
 description KAMERA
 switchport trunk native vlan 200
interface gigabitethernet1/1/6
interface gigabitethernet1/1/7
 description TOKI-MISIA-P2P
interface gigabitethernet1/1/8
 description "TOKI PTP EUAS M"
 rate-limit 5632 128000
 traffic-shape 10752
 switchport trunk native vlan 110
interface gigabitethernet1/1/9
 description TOKI-PTP-VATANPRES
interface gigabitethernet1/1/10
 description DOSAB-BASE
interface gigabitethernet1/1/11
 description "UPS UNTAGGED"
 switchport trunk allowed vlan add 110,120,200
 switchport trunk native vlan 100
interface gigabitethernet1/1/12
 description "TOKI OSAB BASE1"
interface gigabitethernet1/1/23
 description "Toki PTP Gorukle Mimosa"
 rate-limit 5120 128000
 traffic-shape 20480 256000
interface gigabitethernet1/1/24
 description "TOKI PTP GORUKLE YURT M"
exit
which port is broken ? There usually are port groups on the switches, such as 1 -4, 5 -8 etc. If the entire port group is broken, surrounding ports would not work either.
4 nolu port
