Switch
I have two Cisco SF 300-48P 10/100 PoE Managed Switch, and I am trying to connect the switch over 220  feet distance with a Cat 6 cable but it does not work. Data of the cable in the PDF File
If I connect my Computer to it I have internet on the PC, but if I connect the second switch I get no connection.
If I connect the two switch over 10 feet distance it works fine.
Is the distance to long???
In the document of the switch is written 100 meters is possible
I have to do some settings??
Thank you for helping
Br. Raphael
5 Replies 5
Georg Pauwen
you typically would need a crossover cable. On the SF300 you can set the MDIX to 'auto' (page 127/128 of the attached guide)...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
I used a crossover adapter but it does not work with it.
MDIX is Auto
is there a difference between a crossover cable and crossover adapter???
Thanks for help
Hello
100 metres on cat 6 is the limit-  it’s possible taking cabling management into consideration your exceeding the defined limitations of copper
Kind Regards
Paul
Good point ! I seem to recall that there is actually Cat 6 and Cat 6a, where Cat 6 has a limit of somewhere around 50 meters for >10G, whereas Cat 6a goes up to 100 meters for these data rates. Although you don't have 10G ports, at least make sure you are using 6a...
What is cabling management???
Thanks for help
Br. Raphael
