Switchport mode access or switchport mode trunk to connect ASA
Ranbeckycr_2
Experts,
I have a question, I have a Cisco Pix 515e running 8.0(2) do you recommend setting the switchport to trunk or access?
I would like to know the recommended approach, randomly, I can't access the firewall and then we need to reboot the PIX.  (maybe is the pix)
Current Interface Config:
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
------------  I have set all my other ports where only computers connect as follows:   Please let me know if it is ok.
interface FastEthernet0/5-10
switchport mode access
speed 100
duplex full
spanning-tree portfast
Richard Burts
Randall
The title of your question asks about ASA while the body of the question seems to be about pix. I believe that it is the same answer for either platform but perhaps you could clarify which platform we are discussing.
The answer to whether to configure in access mode or in trunk mode depends on how the ASA is configured. By default the ASA treats its interfaces as access ports and supports a single VLAN (with no tagging of frames). But the ASA does support configuring its interfaces as trunks with multiple VLANs supported on the interface and with tagging of frames. So if the ASA is operating in default then configured the port as access while if the ASA is configured for trunking then the port needs to be configured as trunk.
Rick
Rick
Richard Burts
Randall
Rick
Rick
Richard, thanks, you clarified my question, I didn't know what the recommended approach was.
In this case I will set is as access port because there are no other vlans.
Thank you,
Randall
