Traffic shaping on LAG
Hi everyone
I have ASR1001 connected to the provider.  It's a L2 connection. The provider requested to configure LAG with the only interface inside.  We have numerous QinQ connections inside this link.
Is it possible to shape the whole link?
Unfortunately,  I can apply policy to subinterface of LAG, but I can't apply it to the LAG itself
ASR1(config)#int po1
ASR1(config-if)#service-policy output 50M
service-policy output 50M not supported on this target
5 Replies 5
Francesco Molino
Can you please share your policy-map and the version you're running?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi Francesco
Here is a policy-map
policy-map 50M
class All
shape peak 50000000
version is asr1001-universalk9.03.13.06a.S.154-3.S6a-ext.bin
If i recall this isn't supported in this version. I'll try to give you the documentation link where it's written.
Did you try upgrading to latest recommended version (e.g. 3.16 latest recommended version)
Francesco
This box is a temporary solution. I'm going to put there ASR1004, that's why I didn't played with firmware.
It would be great if you could provide documentation about QoS restrictions on IOS-XE versions.
Appreciate it.
Ok I wasn't totally wrong.
This is what's written:
Class-based policing can be configured on an interface or a subinterface, but it is not supported on EtherChannel or tunnel interfaces.
Here is the link I'm referring to:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_plcshp/configuration/xe-3s/qos-plcshp-xe-3s-book/qos-plcshp-class-plc.html#GUID-7B0063DD-26C6-4458-AEA4-2A7CB1B1B3CA
However, you need to activate the capability. take a look here:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-16-5/qos-mqc-xe-16-5-book/aggregate-etherchannel-quality-of-service.html
Then yes you can do it.
Francesco
