traffic slow due to errors and interface resets?(part 1)
bobababurko
OK, I have a 2524 with 2 t1 wics along with two circuits. We have an announcement list that we run like 3 times a week that allowed me to notice that mail was not going out as fast as it ususally does. We are talking about a fraction...like 5% of the normal. Needless to say, our customers do not like that. So, nothing has changed, except a power outage a few days ago and things seemed to run fine after that.
On the router, I see and obscene number of interface resets on the ethernet interface.(there are two serial interfaces(T1 wics) and one ethernet on this router.) I am fairly sure that e0 is a half duplex 10 Mbps int. Icouldn't find any information that suggests otherwise. A show int on all three interface is as follows:
Router#sh int
Ethernet0 is up, line protocol is up
Hardware is Lance, address is 00d0.58ac.fe2d (bia 00d0.58ac.fe2d)
Internet address is 208.51.xx.xx/27
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 3/255, rxload 39/255
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:21:02
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 48/75, 34631 drops
5 minute input rate 1533000 bits/sec, 140 packets/sec
5 minute output rate 139000 bits/sec, 147 packets/sec
225852 packets input, 301172503 bytes, 0 no buffer
Received 7 broadcasts, 0 runts, 0 giants, 34631 throttles
214699 packets output, 34563008 bytes, 0 underruns(3199/2453/0)
0 output errors, 5652 collisions, 69262 interface resets
0 babbles, 0 late collision, 9812 deferred
0 lost carrier, 0 no carrier
Serial0 is up, line protocol is up
Hardware is HD64570 with FT1 CSU/DSU
Internet address is 208.49.147.xxx/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 207/255, rxload 19/255
Encapsulation HDLC, loopback not set
Last clearing of "show interface" counters 00:21:03
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 455
Queueing strategy: weighted fair
Output queue: 44/1000/64/307 (size/max total/threshold/drops)
Conversations 29/117/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 120000 bits/sec, 147 packets/sec
5 minute output rate 1259000 bits/sec, 133 packets/sec
106384 packets input, 13555157 bytes, 0 no buffer
Received 74 broadcasts, 0 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 1 overrun, 1 ignored, 0 abort
102275 packets output, 132357033 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
...continued, next entry
bobababurko
Serial1 is up, line protocol is up
reliability 255/255, txload 36/255, rxload 1/255
Last input 00:09:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:21:04
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 24495
Output queue: 1/1000/64/24372 (size/max total/threshold/drops)
Conversations 0/114/256 (active/max active/max total)
5 minute input rate 1000 bits/sec, 0 packets/sec
5 minute output rate 218000 bits/sec, 7 packets/sec
114563 packets input, 19108949 bytes, 0 no buffer
Received 72 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
105120 packets output, 130625433 bytes, 0 underruns
It seems that the pipe is being filled but the mail seems to be senind slow...like I noted above. Could the resets be responsible for the errors or packets that never get to the destinations, thus not allowing the connections to finish at a timely manner? This is all that I can think of.
Here is a "sho int" of the switch port that the cable from e0 on the router is plugged into:
2924#sh int fast 0/4
FastEthernet0/4 is up, line protocol is up
Hardware is Fast Ethernet, address is 00d0.ba08.56c4 (bia 00d0.ba08.56c4)
reliability 255/255, txload 60/255, rxload 6/255
Keepalive not set
Half-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:26:50
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 274000 bits/sec, 183 packets/sec
5 minute output rate 2391000 bits/sec, 245 packets/sec
295226 packets input, 52730568 bytes
Received 292 broadcasts, 0 runts, 0 giants, 0 throttles
715 input errors, 384 CRC, 331 frame, 0 overrun, 0 ignored
0 watchdog, 31 multicast
395847 packets output, 508992195 bytes, 0 underruns
5 output errors, 10651 collisions, 2 interface resets
0 babbles, 5 late collision, 7958 deferred
what is the problem here? Are the T1 wics bad? I have changed the cable out.....I dont think that I have That many bad cables? I could use some advice.
