Trouble with etherchannels on 2950 switch.
Oliver42
I did a simulation of a network in PT recently and now that I'm working on the real thing with real devices I'm running into a few problems.
As you can see from the picture below the two 2950 switches both have two etherchannels. I configured one on each at first and everything was fine. Then I configured the second one (port-channel 3) and when I connected my ethernet cables to the ports on the switches nothing happened, they stayed down. I then looked at the running-config to find out that my port-channel 3 stated ''flowcontrol send off''.
What does that mean? I've never seen that before.
5 Replies 5
Etherchannel  port must identically, but here one is support flowcontrol other not,
So config flowcontrol.
This command is not shown in run-config, but is shown in show interface
I'll do some research, but I never had to configure flowcontrol. How do I do it?
Hello @Oliver42 ,
flow control off is not a reason for ports to stay down.
I remember that Catalyst2950 had several limitations when dealing with port channels.
In some models only one port of a bundle stayed up and the other one was used as backup.
Post
show version
show etherchannel summary
Hope to help
Giuseppe
Hwllo
sh etherchannel summary
sh etherchannel port-channel
sh spanning-tree blocked ports
Kind Regards
Paul
