Troubleshooting ACLs.
andrea.meconi
Level 2
Level 2
We are using Catalyst 3750-E with IOS version 12.2(53)SE2.
I’m configuring vlan map with extended IP ACL .
ip access-list extended Allowed-Traffic
permit tcp 10.4.254.0 0.0.1.255 10.4.253.0 0.0.0.255 eq telnet
permit tcp 10.4.253.0 0.0.0.255 eq telnet 10.4.254.0 0.0.1.255
vlan access-map VACL 10
action forward
match ip address Allowed-Traffic
vlan filter VACL vlan-list 253
How can I determine if ACL processing is accomplished in hardware?
From configuration guide.
To determine the specialized hardware resources, enter the show platform layer4 acl map.
If the switch does not have available resources, the output shows that index 0 to index 15 are not available.
Thanks.
Regards.
Andrea
Ganesh Hariharan
action forward
Thanks.
Regards.
Andrea
Andrea,
ACL processing is primarily accomplished in hardware, but requires forwarding of some traffic flows to the CPU for software processing. The forwarding rate for software-forwarded traffic is substantially less than for hardware-forwarded traffic.
Check out the below link for more information
http://www.ciscosystems.net/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swacl.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
andrea.meconi
Level 2
Level 2
I’m  configuring an extended IP ACL on SVI.
But this command doesn't show anything!
Thanks.
Regards.
Andrea
