Unable to configure HSRP Virtual ip on IE4010 Switches
We have got the New IE40101 Switches and I am unable to configure HSRP Virtual IP on IE4010 Switches.
DS-SW1(config-if)#standby ?
<0-255>          group number
authentication   Authentication
bfd                   Enable HSRP BFD
delay                HSRP initialisation delay
follow               Name of HSRP group to follow
DS-SW1#sh ver
Cisco IOS Software, IE4010 Software (IE4010-UNIVERSALK9-M), Version 15.2(8)E1, RELEASE SOFTWARE (fc8)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Tue 12-Oct-21 05:13 by mcpre
ROM: Bootstrap program is IE4010 boot loader
BOOTLDR: IE4010 Boot Loader (IE4010-HBOOT-M) Version 15.2(4r)EC, RELEASE SOFTWARE (fc1)
DS-SW1 uptime is 1 hour, 42 minutes
System restarted at 01:26:55 UTC Wed Mar 30 2011
System image file is "sdflash:/ie4010-universalk9-mz.152-8.E1.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent Right-To-Use
Next reload license Level: lanbase
cisco IE-4010-16S12P (APM86XXX) processor (revision V0) with 1048576K bytes of memory.
Processor board ID
Last reset from power-on
3 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
mac-refresh     Refresh MAC cache on switch by periodically sending packet from virtual mac address
name               Redundancy name string
preempt          Overthrow lower priority Active routers
priority             Priority level
redirect           Configure sending of ICMP Redirect messages with an HSRP virtual IP address as the gateway IP address
timers             Hello and hold timers
track               Priority tracking
use-bia          HSRP uses interface's burned in address
version           HSRP version
Mark Elsen
 - Can't see from that output why you can not get HSRP going , check : https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie4010/software/release/15-2_4_EC/configuration/guide/scg-ie4010_5000/swhsrp.html , for guidelines.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
