08-27-2021 02:36 AM
Hi Community
A bit of context we currently use SNMP to pull DHCP info using the following MIBS. Use Prometheus -> SNMP_exporter - Grafana to visualise,
CISCO-IETF-DHCP-SERVER-MIB
CISCO-IETF-DHCP-SERVER-EXT-MIBS
It works without issues, e.g if i use cDhcpv4ServerSubnetSharedNetworkName - I can see all the DHCP scopes..
however when I use cDhcpv4ServerSubnetFreeAddresses MIB - I can only see 4 out of the 6 scopes, On the cli I can see all the scopes and the leases.
Thanks In advance.
08-27-2021 05:11 AM
tough one. First of all, I would check if the configured SNMP version (1/2/3) matches on the Cisco and the Prometheus side. That said, can you post your snmp.yml file ?
08-27-2021 06:34 AM
We use SNMPV3, and it's only this when scraping the cDhcpv4ServerSubnetFreeAddresses-MIB that i can't see all the DHCP leases. I can see all the DHCP scopes.
e.g
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.30.x",cDhcpv4ServerSubnetSharedNetworkName="AWS1-5-Primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.31.x",cDhcpv4ServerSubnetSharedNetworkName="ASW1-1-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.32.x",cDhcpv4ServerSubnetSharedNetworkName="ASW1-2-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.33.x",cDhcpv4ServerSubnetSharedNetworkName="ASW1-3-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.34.x",cDhcpv4ServerSubnetSharedNetworkName="asw1-4-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="10.x.35.x",cDhcpv4ServerSubnetSharedNetworkName="ASW-LG-1-primary"} 1
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="10.x.30.0"} 137
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="10.x.33.0"} 139
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="10.x.34.0"} 138
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="10.x.35.0"} 115Can't understand why I cannot see the below entires for cDhcpv4ServerSubnetFreeAddresses
10.x.32.x"
"10.x.31.x"
08-27-2021 06:50 AM
SNMPV3 is been used, snmp.yaml seems to be correct. This is what i was referring to am not seeing all the scopes for cDhcpv4ServerSubnetAddress.. can't figure out why.
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="x.x.30.0"} 137
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="x.x.33.0"} 139
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="x.x.34.0"} 138
cDhcpv4ServerSubnetFreeAddresses{cDhcpv4ServerSubnetAddress="x.x.35.0"} 115
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.30.0",cDhcpv4ServerSubnetSharedNetworkName="AWS1-5-Primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.31.0",cDhcpv4ServerSubnetSharedNetworkName="ASW1-1-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.32.0",cDhcpv4ServerSubnetSharedNetworkName="ASW1-2-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.33.0",cDhcpv4ServerSubnetSharedNetworkName="ASW1-3-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.34.0",cDhcpv4ServerSubnetSharedNetworkName="asw1-4-primary"} 1
cDhcpv4ServerSubnetSharedNetworkName{cDhcpv4ServerSubnetAddress="x.x.35.0",cDhcpv4ServerSubnetSharedNetworkName="ASW-LG-1-primary"} 1Kind regards
Anuna
