Unable to power some APs with PoE+
Ludofloria
Hey there
I currently use second hand Cisco 2960S switches (full ref: C2960S-24PS-L).
According to the Data Sheet, they are 802.3at-compliant, meaning I can use them to power up 30W devices.
I purchased multiple Netgear APs, which are PoE+ enabled and should be perfectly powered-up by the switches.
However, when I plug them into my switches, I got a « Insufficient Power » error. The AP seems to believe it's connected to a 802.3af port.
How can I force a port to be 802.3at and make my APs work as intended?
I've connected those AP to a Sophos XGS126 firewall with two PoE+ port, and the APs boots up with no errors, meaning the problem comes from the switches giving them the Power.
Thanks in advance for your help
32 Replies 32
Run lldp in SW
I think it issue here
MHM
Hello !
I ran this command and I see my AP. And with show power inline, I see a power of 30W attributed to the port.
Can I see
show inline power
MHM
Hello
Here is show power inline:
Mark Elsen
 - Enable LLDP on the switch (overall) and or the ports for the APs
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello !
lldp is enabled globally on the switch (unless I need to do something else than lldp run?)
Hello @Ludofloria ,
you can check by yourself using
show lldp neighbors
it will tell you if LLDP is enabled, if enabled provides a list of LLDP neighbors listinng local an remote port-IDs
Hope to help
Giuseppe
LLDP is enabled globally:
And my AP is rightfully detected as a WLAN Access Point
debug ilpower port <<- run this denug let see what error we get
MHM
It's enabled now
How can I check the debug log?
Reconnect AP and debug must appear.
MHM
I'm connected via telnet to the switch and I don't see any debug log.
Must I use the console port?
No friend
Disconnect and reconnect AP
Let see debug of inline appear
MHM
The only thing I have managed to display on my telnet session is this:
