Unable to ssh/telnet into Nexus 7010.
jaijo01
Getting the following error when enable "terminal monitor" on it.
UDC-CS-L05-02# 2013 Apr  8 18:15:52 UDC-CS-L05-02 %LOCAL7-3-SYSTEM_MSG: getsockname: Socket operation on non-socket (errno = 88) - dcos-xinetd[25617]
2013 Apr  8 18:15:52 UDC-CS-L05-02 %LOCAL7-3-SYSTEM_MSG: Failed to contact identity server at ::ffff:203.8.5.74: system error - dcos-xinetd[25617]
Nexus running on the following version:
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 3.17.0
  loader:    version N/A
  kickstart: version 4.2(2a)
  system:    version 4.2(2a)
  BIOS compile time:       03/23/08
  kickstart image file is: bootflash:/n7000-s1-kickstart.4.2.2a.bin
  kickstart compile time:  9/25/2009 9:00:00 [09/28/2009 06:06:24]
  system image file is:    bootflash:/n7000-s1-dk9.4.2.2a.bin
  system compile time:     9/25/2009 9:00:00 [09/28/2009 06:35:38]
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 4129600 kB of memory.
  Processor Board ID JAF1409BCBE
  Device name: UDC-CS-L05-02
  bootflash:    2000880 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 1096 day(s), 1 hour(s), 54 minute(s), 23 second(s)
Last reset
  Reason: Unknown
  System version: 4.2(2a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
CMP (Module 6) ok
CMP Software
  CMP BIOS version:        02.01.05
  CMP Image version:       4.2(1) [build 4.2(1)]
  CMP BIOS compile time:   7/13/2008 19:44:27
  CMP Image compile time:  9/25/2009 9:00:00
CMP (Module 5) ok
CMP Software
6 Replies 6
InayathUlla Sharieff
Hi Chandran,
First thing first is the firmware which you are running on the device is quite old and it could be bug for this issue.
Hence I request you to plan for the software upgrade first before we torubleshoot this issue.
Inayath
*Plz rate the usefull posts.
Hi Inayath,
Yes, i know the firmware is quite old.
The thing is we have another 8 devices wit the same firmware but no issues. I can telnet to it from a device connected to it.
But it randomly fails and i cant telnet from my source. I get the following error:
The rest of the 8 devices, i have no issues telnetting from my source.
The configuration are all same.
Hi Jai
Try the following on your box:
no feature telnet
no feature ssh
feature telnet
feature ssh
Marcel
Hi Marcel,
I do not console access to the device. Disabling/renabling the ssh and telnet feature.
Will it disconnect me from the current seeion?
Thanks.
Hi Jay,
1-Kindly check if there are any access-list blocking the telnet session?
2- If you have telnet to the device then before disabling it enable the SSH and generate the key for the same and try ssh into the device?
Below is the method:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_ssh.html
Please let us know if this doesnt help.
Inayath
Tried the following on your box:
no feature telnet
no feature ssh
feature telnet
feature ssh
But still did not work.......
There's no access-list blocking access as well...
Any other ideas?
