upgrade 6807 in VSS Quad-SUP using ( Fast Software Upgrade )
dqalib23
HI,
Planning to upgrade 6807 in VSS Quad-SUP using ( Fast Software Upgrade )
From version s6t64-adventerprisek9-mz.SPA.155-1.SY7 TO s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin
Have few hours of maintenance window and would like to know best approach for this .
Sups are in slot 3/4 on each 6807 see attached config :
1) Can someone kindly confirm the directories I need to upload the new image to as cisco doc says (disk0: and slavedisk0:) ?
---------https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-5SY/config_guide/sup6T/15_5_sy_swcg_6T/enhanced_fast_software_upgrade_efsu.html
2) and finally is this guide all I need in this or is there more ?
HI Leo
Thanks allot for your time , one more thing I have put together below steps for the upgrade any comments ?
1) Copy the IOS to the primary bootflash:
Copy tftp://suchAndSuch/s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin bootdisk:/
2) Copy the IOS to the secondary bootflash:
copy bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin slavebootdisk:
3) Remove the boot variable string pointing to the old IOS
no boot system bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY7.bin
no boot system bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY5.bin
4) Add the new boot variable string pointing to the new IOS
boot system bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin
5) Insert the boot variable string pointing to the old IOS
6) Make sure the config-registry is 0x2102
config-register 0x2102
Save the config
show bootvar (to confirm the correct variable)
redundancy reload shelf
Reboot
16 Replies 16
Reza Sharifi
If you are trying to load it to the internal flash, it should be bootdisk: and slavebootdisk: and not disk0.
BOOT variable = bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY7.bin,12;bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY5.bin,12;
Leo Laohoo
Please avoid ISSU/FSU/eFSU/xFSU.  ISSU/FSU/eFSU/xFSU only works in "corner cases", labs or in demo.  When it fails, it will fail in a spectacular fashion.
If someone is still h!llbent with ISSU/FSU/eFSU/xFSU regardless, make sure TAC is on a WebEx call so they can see for themselves when the process eventually fails.
That will depend on the line cards.
ISSU/FSU/eFSU/xFSU do not support manual FPGA upgrade.
Make sure to have console access to both units.
HI Leo
Save the config
Reboot
The steps look correct, but if you have 2 sups in each switch, you want to load the new IOS in all 4 sups first.
copy bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin sw1-slot3-bootdisk:
copy bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin sw1-slot4-bootdisk:
the same for sw-2
That is what I was missing thanks for that Reza, will upgrade this weekend will update many thanks
Also, for step 6, you don't necessarily need to type the command. As long as "sh ver" or "sh redun" shows the correct config-register (0x2102), you are good to go. It is also very important to save your config at the end and before you reload, which is step-7
And one more thing, once you load the IOS in the first sup, you can always copy from the first sup to the second sup (from slot-3 to slot-4). I have done this type of upgrade with one sup in each chassis. So, hope all goes well with 4.
Good Luck!
I agree with @Reza Sharifi, steps look good.
Make sure to have console access to the switch.  In case the FPGA required message appears, the only way to perform the FPGA upgrade will be console.
HI Community
For switch one I don't the see SW1-slot3-bootdisk:  is that normal do I only Upload the images
bootdisk:
slavebootdisk:
sw1-slot4-bootdisk:
sw2-slot3-bootdisk:
sw1-slot4-bootdisk:
HI
Change went successful , downtime of 12minutes , thanks to all of you
Good to hear everything went like flawlessly.
Did you have to do a manual FPGA upgrade?
Hi dqalib23,
Please, could you share the procedure that you have took to upgrade the box?
I will do the same upgrade 6807-XL SUP-6T (Quad) in VSS mode from 15.4.1 to 15.5.1 IOS version on a few days ahead.
Thanks in advance!
