Upgrade memory and flash on Cisco 871W
Nicky Maddison
I have upgraded a Cisco 871W router with the following kits. Before the parts replacement, I have saved the flash: to a usb dongle.
MEM870-32F-MT_BIE
MEM870-128D_ALFAIX
I would like ton install the latest version of IOS for this device. (c870-advsecurityk9-mz.151-4.M10.bin).
The router is booting in rommon and I always get "permission denied" what ever command I try!
Can you help me re configuring this device?
Thanks a lot.
Reza Sharifi
So, if you remove the extra memory you just installed, would the router boot correctly?
