Using the 3750 as a non-stack switch..how to set it up?
RabbitSF
Currently we have two WS-C3850-24P work as our core switches and connected with 6 other WS-C2960X-48FPS-L across our school LAN.
I recently got 4 used WS-C3750-48PS-S switches and thought I could use them as backup in case the 2960X crashes. The question is if this is workable? If yes, how to configure from the CLI? I already reset the 3750 to factory default. Any command I need to run to clear anything else? Anything else that I need to be aware of?
Or simply put, can I make the 3750 work as a 2960x? and how?
I am not a pro on Cisco switches so forgive me if that sounds to be a stupid question. Thanks much!
Hit switch(config)#no switch 7 provision then upgrade your code to release 12.2.55-SE11 "c3750-ipbasek9-mz.122-55.SE11.bin". Everything should be good.
22 Replies 22
Joseph W. Doherty
Should be.
Pretty much as you do the 3850s or 2960Xs, i.e. start with console connection.  Once switches are configured with a management IP, configured to support telnet, and connected to network, you should be able to further configure with a telnet app.
Maybe an initial write erase, but if they are reset to factory default, you should have a "blank slate".
If you want to use them like 2960X, i.e. L2 switches, don't enable IP routing.  If a L2 role, their configurations should be very much like your 2960Xs.
If you have more than one 3750 in the same location, you could also consider stacking them, and then you configure the stack as a single logical unit.
When the 3750 boots it shows the following,
*Mar  1 00:00:31.264: %STACKMGR-4-SWITCH_ADDED: Switch 7 has been ADDED to the stack
*Mar  1 00:00:43.872: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:45.206: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:01:06.253: %STACKMGR-5-SWITCH_READY: Switch 7 is READY
*Mar  1 00:01:06.253: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 7 has changed to state DOWN
*Mar  1 00:01:06.253: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 7 has changed to state DOWN
*Mar  1 00:01:07.100: %STACKMGR-5-MASTER_READY: Master Switch 7 is READY
It looks like the Switch 7 boots as the master of the stack and it does say "Swtich 7 has been ADDED to the stack". If that's the case, do I need to anything to get rid of that settings?
That means 3750 was in a stack - existing config- As Joe stated reset it back to default settings, the concept is to delete its config+vlan database then reload with no save option so you can configure it properly.
Please see
Reset Switch Configuration+Reset VLAN Information
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
Note: check with your senior staff before making any changes to production.
Good luck!
I tried both
write erase
and
write startup-config
but they did not work. The switch still boots saying "Switch 7 booting as Master" and gives me the above message I quoted.
Anything else I need to do?
Try to delete config.text and vlan.dat from rommon that should help. Good luck!
I don't have the config.text any more. The following is all I have.
Switch#show flash:
Directory of flash:/
    5  drwx         128  Aug 21 2009 15:50:01 +00:00  c3750-ipbase-mz.122-35.SE5
    6  -rwx    10294949  Aug 21 2009 16:00:56 +00:00  c3750-ipbasek9-mz.122-50.SE3.bin
15998976 bytes total (3251200 bytes free)
Perform that in rommon. Power the switch off then hold the mode button while the switch is booting up until you get the rommon window.
switch: dir flash:
Directory of flash:/ 2 -rwx 1803357 <date> c3500xl-c3h2s-mz.120-5.WC7.bin 4 -rwx 1131 <date> config.text 5 -rwx 109 <date> info 6 -rwx 389 <date> env_vars
7 -rwx 201 <date> vlan.dat
403968 bytes available (3208704 bytes used) switch: delete flash:/config.text
switch: delete flash:/vlan.dat
I got the following. Did I do something wrong messing up the file system?
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:26:0a:e9:ca:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch: dir flash:
unable to stat flash:/: invalid argument
Try these commands "init_flash" and "load_helper" before above instructions. Let me know how it goes.
No luck. See below,
Switch(config)#
system software:
    flash_init
    boot
switch: init_flash
Unknown cmd: init_flash
switch: load_helper
Unknown cmd: load_helper
I heard that if I hold the Mode button more than 10 seconds which I did accidentally, it will erase something. I wonder if I messed it up.
I am confused. Are you able to boot to system flash or not? I see "switch(config)#".
Yes, I can boot to system flash. The "switch(config)#" is just an accidental capture from the previous terminal section.
Okay. then you should be able to default your switch. see below:
Switch#dir flash:
2 -rwx 1916 Mar 23 2017 06:35:58 +00:00 private-config.text
3 -rwx 21279744 Mar 23 2017 05:13:08 +00:00 c2960x-universalk9-mz.152- 2.E6.bin
4 -rwx 3096 Mar 24 2017 06:35:22 +00:00 multiple-fs
5 -rwx 556 Mar 23 2017 06:35:48 +00:00 vlan.dat
6 -rwx 2865 Mar 23 2017 06:35:57 +00:00 config.text
672 drwx 512 Jan 10 2034 10:52:34 +00:00 dc_profile_dir
122185728 bytes total (73604608 bytes free)
Switch#delete flash:vlan.dat
Delete filename [vlan.dat]?
Delete flash:/vlan.dat? [confirm]
Switch#delete flash:config.text
Delete filename [config.text]?
Delete flash:/config.text? [confirm]
Switch#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
Switch#
Mar 31 09:33:43.318: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvramrelo
Switch#reload
Proceed with reload? [confirm]
Mar 31 09:33:50.959: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
Yes, I ran all those commands before. But it still says the following:
So I believe that's the way it's. I also have the following and I believe it's ready for me to use it as a stand alone switch. Am I correct?
Switch#sh switch
Switch/Stack Mac Address : 0026.0ae9.ca80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0026.0ae9.ca80     1      0       Ready
