VLSM Subnetting
majedalanni
Hi all,
I have question, as I know VLSM  make subnets with different CIDR
like 192.168.1.0/25, 192.168.1.128/26 and 192.168.1.192/26
can I do it backward like
192.168.1.0/26, 192.168.1.64/26 and 192.168.1.128/25 ??
Thanks in advance
Majed
Richard Burts
Majed
Yes you certainly could arrange the subnets in either order - either the /25 first and then the 2 /26s or the /26s first and then the /25. As long as the /26s are contiguous it will work. Note that it would not work to try to do /26, then /25, then the other /26.
Rick
Rick
Richard Burts
Majed
Rick
Rick
