VRF configuration on layer 2
Hello All,
I wanted to know if we can create a VRF on layer 2 port-channel or on a vlan. Someone please help me out
Thank you,
Sameetha
Mark Malone
not at layer 2 as a vrf is for logically sperating routing tables at layer 3  , if these ports have no ip on them the vrf is pointless , routing must be enabled on the device and the port must have an ip on it for vrf to work
10 Replies 10
Mark Malone
Here is the scenario in working one:
we have created vrf instance in core with dhcp configured and then extended from core to layer 2 sw via access port core and l2 switch connected with access vlan 19 for example and from lay 2 to wlc there is  a trunk my confusion is will vrf  pass the traffic to wlc
Thanks a lot Mark!!
I actually got this question, since I am trying to send the syslog messages from Nexus switch to be sent to the syslog server
switch# configure terminal
switch(config)# logging server 172.28.254.254 5 local3
Please let me know if this configuration is right
Sameetha
Yes that will work , here is mine of one of my 7ks Nexus , you wouldn't need the vrf unless your doing out of band mgmt. so what you have should work fine , I would also source it off an up/up interface like a loopback , mine is just set to notification facility 5 rather than yours critical 3 reporting
logging server x.x.xx 5 use-vrf management
logging source-interface loopback 3
logging monitor 6
Thanks Mark . Though it's not working , Please confirm the following configuration for me
on the Nexus 5545 switch
 monitor session 1
 logging server 172.28.254.254 7
logging monitor 1
on the server side I have to just add the loopback IP address
Please correct me, If I went wrong.
Thank you,
Sameetha
the server ip should be 172.28.254.254
can you post the command ....show logging server ... from the nexus
You may have to use a vrf , do you have any management ip on the device at all ?
the nexus comes with 2 vrfs enabled by default , default & management , you could try add the vrf under the management vlan ip if not a physical interface
example
interface vlan 1
  description MGMT
  vrf member management
  ip address x.x.x.x/x
logging server x.x.x.x use-vrf management
or if that does not work try the default vrf
You can see these vrfs with.......show vrf
Thanks a ton Mark !! Finally it started working, first I tried using management vrf and it did not work and later I used default vrf
Here is the snapshot of my configuration on nexus 5548 switch
logging server x.x.x.x 7 use-vrf default
logging source-interface loopback 0
logging monitor 7
Once again thanks a lot, I really appreciate your time and patience
Sameetha
Ah very good glad you got it ;)
looks fine , can you ping that ip from the Nexus ? that may be your issue if its not working , thats all thats required to setup syslog same as IOS as below
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/system_management/502_n1_1/b_Cisco_n5k_system_mgmt_cg_rel_502_n1_1/Cisco_n5k_system_mgmt_cg_rel_502_n1_1_chapter9.html#task_5793349949823830091
Configuring syslog Servers
You can configure up to three syslog servers that reference remote systems where you want to log system messages.
SUMMARY STEPS
1.    switch# configure terminal
2.    switch(config)# logging server host [severity-level [use-vrf vrf-name [facility facility]]]
3.    (Optional) switch(config)# no logging server host
4.    (Optional) switch# show logging server
5.    (Optional) switch# copy running-config startup-config
DETAILED STEPS
  Command or Action Purpose
Step 1 switch# configure terminal
Enters configuration mode.
Step 2 switch(config)# logging server host [severity-level [use-vrf vrf-name [facility facility]]]
Configures a host to receive syslog messages.
  • The host argument identifies the host name or the IPv4 or IPv6 address of the syslog server host.
  • The severity-level argument limits the logging of messages to the syslog server to a specified level. Severity levels range from 0 to 7. Refer to Table 1
  • The use vrf vrf-name keyword argument identifies the default or management values for the VRF name. If a specific VRF is not identified, management is the default. However, if management is configured, it will not be listed in the output of the show-running command because it is the default. If a specific VRF is configured, the show-running command output will list the VRF for each server.
    Note    The current CFS distribution does not support VRF. If CFS distribution is enabled, then the logging server configured with the default VRF will be distributed as the management VRF.
  • The facility argument names the syslog facility type. The facilities are listed in the Cisco Nexus 5000 Series Command Reference. The default outgoing facility is local7.
Step 3 switch(config)# no logging server host
(Optional)
Removes the logging server for the specified host.
Step 4 switch# show logging server
(Optional)
Displays the syslog server configuration.
Step 5 switch# copy running-config startup-config
(Optional)
Copies the running configuration to the startup configuration.
Thanks Mark . I am able to ping from switch to the server and vice versa, though the server is not having the logs from the switch
Sameetha
