VS-S720-10G port channel error disable(not vss mode)
tatsun
hi
i have 2 x c6509e, each equiped with 1 x VS-S720-10G(with 2 x 10g port), i need to confiure portchannel with both 10g port between this two c6509e, and need to use standalone mode only(not VSS), however i found error disable from one side of switch after enabled the portchannel from 10g port,
i checked all fiber cable work fine, if not use portchannel configure, i can bring up both 10g port those switches,
here's the port channel configure(identical from both c6509e):
interface Port-channel1
switchport
switchport trunk encapsulation isl
switchport mode trunk
interface TenGigabitEthernet5/4
switchport
channel-group 1 mode on
interface TenGigabitEthernet5/5
switchport
IOS Version 12.2(33)SXH4
Giuseppe Larosa
Hello Tat,
try to use 802.Q encapsulation
may you post the error message you can find it with
sh log
Hope to help
Giuseppe
i do not know what is happen, but after upgrade to 122-33.SXH5.bin, the portchannel is work fine for 10g port,thanks!
