vss dual-active crash
fly
Level 2
Level 2
HI everyone
   our two 6509 configured VSS , standby box SUP crashed at mid night and not
came back online itself,remain in ROMMON.
   we found at same time , one upstream switch  has two interfaces
connect to this two box seperatly, this two interfaces were down at same time.
   all communication through VSS had been down for almost 8 hours until we found
problem on morning  and reboot standby box, now it is ok
   but in this failure, standby box crashed , active box lost vsl and dual-detect
link , this was not dual-active , why upstream switch two interfaces were all down.
   I think during standby box sup crashed. in this short moment,TWO BOXES WERE NOT STABLE
, active box DUAL-DETECT MECHANISM had some LITTLE opportunity or  time to detect dual-active, and shutdown it's interface.and
BUT unforturnately standby box hadn't come back and remained in ROMMON. so upstream switch two interfaces were all down
   if I am correct, this is ridiculous, because i can't avoid this kind of standby box sup crash failure .
does one active box in VSS don't has ability to come back from this failure automatically.
how can I config to made old-active box interface come back if standby box go into ROMMON status for a long time.
 THANK you!
Tom
Shafiek75_2
Looks like your Upstream switch MEC (port channel) was not configured properly or for some reason, STP kicked in, even thought with VSS STP should be automatically disabled.
