VSS in Cisco 9410R
prashanma
Hi All,
Do C9410R support VSS ?
Because in datasheet it says "Cisco StackWise Virtual is supported only on Cisco Catalyst 9404R and Cisco Catalyst 9407R switches."
@prashanma wrote:
According to references in above stack-wise virtual only supports for 9404R and 9407R.
Is there anything like stack-wise virtual for 9410R ?
No, there is none.
You'll need to wait for a firmware that will/might support StackWise Virtual & 9510R.
8 Replies 8
Leo Laohoo
According to the Release Notes for 16.9.1 (LINK), StackWise Virtual is supported only on 9404R & 9407R chassis:
Cisco StackWise Virtual is a network system virtualization technology that pairs two switches into one virtual switch to simplify operational efficiency with a single control and management plane.
Note
The feature is supported only on these chassis models and supervisor modules:
  • Chassis Models—Catalyst 9404R Switch and Catalyst 9407R Switch.
  • Supervisor Modules
    • Cisco Catalyst 9400 Series Supervisor 1 Module (C9400-SUP-1). The feature requires a special, additional, C9400-SUP-UPG-LIC= license with this supervisor module.
    • Cisco Catalyst 9400 Series Supervisor 1XL Module(C9400-SUP-1XL).
Is there any technology like VSS for 9410 ?
Hello
My understanding VSS isnt support on the catalyst 9Ks it only stack-wise virtual
Kind Regards
Paul
No, there is none.
Thank you Leo
StackWise is supported on c9410R, as long as you have C9400-SUP-1XL-Y, and use Cisco IOS XE Gibraltar 16.11.x
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-11/release_notes/ol-16-11-9400.html
Hi all
could you tell me if a couple of one C9407R and one C9410R could form a stackwize virtual ?
thank you in advance.
Florent
