VSS upgrade
arunas.usonis
Hello, I have running VSS (WS-C6509-V-E,  SUP720) which looking to upgrade from IOS SXH5 to SXI6.
I came accross with some information that I should upgrade boot image too ? I looked under sh boot but
I do not see that there should be used any boot image. Under sh ver I can see only in addition -
System Bootstrap, Version 12.2(17r)SX7. So the question is - when is that boot image used ? Is it applicable
only in specific hardware scenarious and not applicable for me ?
On Cisco download page you can find IOS s72033-ipbasek9-mz.122-33.SXI6.bin + boot image s72033-boot-mz.122-33.SXI7.bin
Also somewhere it was saying that those versions have to match.
And also another question - do I need to upgrade rommon in this case ?
switch#sh rom-monitor switch 1 slot 1
Region F1: INVALID
Region F2: INVALID
Currently running ROMMON from S (Gold) region
Thanks for claryfing
Arunas
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
That BootROM is used when booting the RP.  There's another BootROM that's used booting the SP.  You probably don't need to upgrade either, but the release notes should have additional details.
Reza Sharifi
The BootRom you aer running is fine.  You don't need to upgrade it.
Thanks for letting know guys
Arunas
