WAN interface sending DHCP NAK
davidfield
Level 3
Level 3
Hello Cisco community
I have an issue on a recent install where our cisco 867 is connected at site to a carriers wireless bridge to supply internet.  They have bridged a public IP to our WAN G1 interface and we are NATing traffic. Our router is running DHCP scopes for the internal networks.  They have however reported that our router is sending DHCP NAK's our the WAN port back onto their network thus being seen by other customers sites.
I have applied the following Access list but they still say I’m sending NAK’s.  I assume due to the NAT it overrides the Access list.
interface GigabitEthernet1
ip address 195.X.X.X 255.255.255.224
ip access-group Deny_DHCP out                                                              <- trying to block DHCP out wan port
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip access-list extended Deny_DHCP
deny   udp any any eq bootpc
deny   udp any any eq bootps
permit ip any any
I have just now applied swapped the ACL so it is blocking DHCP IN requests on the WAN port as I assume my router is sending Nak's because it is processing the inbound requests.
Am I on the right path here?  Is there another way to do this?
Dave
Interface access list in out direction does not filter router generated packets (DHCP NAK  in your case).
Your router is sending NAK because it received DHCP request on that interface.
You can filter DHCP requests in inbound direction on WAN interface:
ip access-group Deny_DHCP in
Same behavior on 7600 router.
If you have any dhcp pool configured on router (even for different vrf), router sends NAK on all L3 interfaces on which  DHCP request message is received.
Cisco Freak
Level 4
Level 4
Dave,
The fundamental question is why your router is sending DHCP NACK in the WAN interface.
Do you see any DHCP request packet hitting the WAN interface? If so, who is requesting DHCP IP on your WAN interface.
A DHCP NACK is generated as a reply to a DHCP request from a client. We need to identify who is that client that requesting IP from you through the WAN interface. All the LAN DHCP request should hit the LAN interface of the router not the WAN interface.
Thanks Rade and Cisco Freak,
I applied the Access List about a month ago and stopped the packets.  We are sharing a wireless bridge in a rural area from a local ISP. They are using a single AP and antenna setup for a number of clients but there is no isolation between us hence I see their DHCP requests.
Dave
