Weird login problem with 3560G
nicolasjuarez
Hello, i have a weird problem.
We have a WS-C3560G-24TS-S and i can't log in with a certain username. My cfg is something like this:
username admin privilege 15 secret 5 Whatever123
username user1 privilege 7 secret 5 cisco123
I can login with "admin" but when i try logging in with "user1" by ssh or telnet, i can't unless i change it's secret password...
I mean:
1) Log in: user1 / Password: cisco123 = Access Denied
Then, i change user1 secret to "root"
2) Log in: user1 / Password root = Access Granted
Weird! I tried deleting the username and creating it again, but same problem always. The problem is that i need the username to be "user1" and the secret "cisco123".
6 Replies 6
Paul Chapman
Level 4
Level 4
Hi -
You seem to have a basic syntax error.
username user1 priv 7 secret 5 cisco123
Is not the same as
username user1 priv 7 secret cisco123
The first has the "5" keyword in it which indicates that the following string is already encrypted.  The second is what you should actually be doing.
PSC
Hi, after secret 5 i have the encripted string, i just didn't copy here the encripted string so i could show you the problem
try 'login local' instead of 'login authentication default' under the VTY lines:
line vty 0 4
 login local
 transport input ssh telnet
Tried that, but no luck. I guess i will have to reboot the device and see what happens.
what does your configuration look like ? It should look like this:
aaa new-model
aaa authentication login default local
line vty 0 4
Yup, i have all that lines in my cfg
