What is ethpm in Nexus switch?
amit.sardana
Cisco Nexus switches are configured with configurations components that include "ethpm" in it.. Can someone tell me what is the significance of ethpm related configurations?
e.g.
logging level ethpm link-up error
logging level ethpm link-down error
Thanks a lot Reza
Hello Amit, please mark Reza's post as the answer, rating the post will help others who may have the same question as you in the future.
Thank you
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
The link in the answer is outdated. One can find explanation of ethpm here:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/fundamentals/configuration/guide/b_Cisco_Nexus_7000_Series_NX-OS_Fundamentals_Configuration_Guide/b_Cisco_Nexus_7000_Series_NX-OS_Fundamentals_Configuration_Guide_Release_6-x_chapter_...
Ethernet Port Manager (EthPM)—Provides software values for the following parameters:
Link state—Provides software support on Ethernet interfaces, Fabric Extender (FEX) interfaces, and breakout interfaces.
Flow control—Provides software support on Ethernet interfaces, FEX interfaces, breakout interfaces, and port-channel interfaces.
FEX fabric port or any other port—Provides software support on FEX fabric port or any other port.
Native VLAN—Provides software support on L2 Ethernet interfaces, L2 FEX interfaces, L2 breakout interfaces, and L2 port-channel interfaces.
