what is the difference between switch mode and switchport mode ?
dolanduck.
studying for the ccent  exam and i want to know the difference and seems i cant find info on this.
Seb Rupik
Hi there,
Are you seeing these commands in configuration examples?
Cisco CLI can perform command auto-complete on minimal input. Under an interface 'switch' expands to 'switchport' so switch mode and switchport mode are in fact the same command.
cheers,
Seb.
Reza Sharifi
They are the same thing.
switch mode is short for switchport mode
so they do the same thing? like switch mode access does the same thing as switchport mode access ?
Correct. If you issue switch and then press the tab key, it will complete it for you by showing switchport. So, they are the same thing. switch is short for switchport.
Seb Rupik
Hi there,
cheers,
Seb.
