What is the main difference of the SW feature between LAN lite and LAN base in IE-2000?
xjackey.shiue1
We are thinking to deploy CCTV network for factory,
but it is hard for us to choose between IE-2000 LAN lite and LAN base
and the SW feature seems differ from catalyst 2960's  LAN lite and LAN base
So, Could anyone please tell us what is the difference of the SW feature between LAN lite and LAN base in IE-2000?
It will be much helpful if anyone have comparison table showing specific SW feature
One more question, IE-4000 also said its LAN base, and it confused me because it seems like having more SW functionality?
Many Thanks!
Charles Hill
Posting below discusses the differences between lan lite and lan based.
https://supportforums.cisco.com/discussion/10939246/catalyst-2960-s-lan-base-and-lan-lite
You can also go to the link below to compare the two.
https://software.cisco.com/selection/research.html#?mode=&tid=F&pidl=281204560&sidl=280805680&crl=&crtl=&fidl=1471&pidr=284135358&sidr=&crr=&crtr=&fidr=
I have seen several postings on here where it is recommended to stay away from lan lite.
Hope this helps,
Please rate helpful posts.
Thanks.
