WS-C3560X-24T-S management interface configuration
rooki3
Hello everyone,
I have a question regarding management interface config of the switch below:
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.0(2)SE             C3560E-IPBASEK9-M
License applied:
#sh license
Index 1 Feature: ipservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Count: Non-Counted
I am trying to configure the management interface (fa0/0). Below is the ip config
it is a unique IP and plugs to a physically isolated network (OOB Network). On the other end is a L3 Meraki switch.
interface FastEthernet0
ip address 192.168.222.68 255.255.255.240
no ip route-cache
end
The interface is up but not able to ping from the L3 Meraki switch to this port.
Can I configure this with the current image and license I have on the switch.
Or do I need to use vrf (I have used this on other cisco switches).
Am I missing anything on the switch.
NOTE: ip routing is not enabled on the above switch
Kindly let me know if you require further details.
16 Replies 16
Thanks for the help. I will try this and would need to make sure that switch can still send packets to the correct trunk for 172.16.x.x subnets.
rooki3
Hi Everyone,
Thank you for all your help. Just wanted to update something on the post. We were able to purchase the a new support license on the switch and get the universal image on the switch. Also the switch already had the ipservice license on it which I was able to use.
I am now able to have an OOB management interface with vrf on the OOB network and another inbound management interface on an internal network.
