WS-C3850-24P-L
Ibrahim Jamil
Level 6
Level 6
Hello Guys
I have this mode WS-C3850-24P-L , i need to upgrade the IOS to support  Trustsec and SXP , pls advise which IOS feet for this Feature ,
thanks
Mark Malone
cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin with ip services or ipbase license supports trustsec
you can see it does in the feature navigator when you check the software or platform and pick the license type
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Mark Malone
Hi Mark
thanks for ur time to answer my thread
when i download the below IOS , do i need smart License to activate security features such trustsec
thanks
If your switch is only running lanbase (check with show license right-to-use ) then yes you need a license its only supported on the 2 above services and base , each of these would require a license , ipbase would be cheaper than ipservices to buy
thanks Mark
