WS4510R-E with two Supervisor 6-E
Erico Verissimo
Hello all,
I have a 4510R-E with two Sup6-E x2 10gb and my question is: Can I reach 40gb of connection (forwarding traffic) between 4510R-E and NX5K?
Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 12.2(53)SG1
cisco WS-C4510R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID SPE13300188
MPC8548 CPU at 1.33GHz, Supervisor 6-E
NAME: "Linecard(slot 5)", DESCR: "Supervisor 6-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6-E , VID: V05 , SN: JAE1345NP86
NAME: "TenGigabitEthernet5/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: FNS134914ZX
NAME: "TenGigabitEthernet5/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: FNS134914ZW
NAME: "Linecard(slot 6)", DESCR: "Supervisor 6-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6-E , VID: V05 , SN: JAE1345NPK4
NAME: "TenGigabitEthernet6/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: FNS134914CF
NAME: "TenGigabitEthernet6/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: FNS135005CA
Redundant System Information :
Available system uptime = 3 years, 41 weeks, 4 days, 10 hours, 42 minutes
Switchovers system experienced = 0
Standby failures = 1
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = RPR Reason: Unknown
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 3 years, 41 weeks, 4 days, 10 hours, 41 minutes
Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 12.2(53)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 30-Oct-09 18:26 by prod_rel_team
BOOT = bootflash:cat4500e-entservicesk9-mz.122-53.SG1.bin,1;
CONFIG_FILE =
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 6
Current Software state = STANDBY COLD
Uptime in current state = 30 weeks, 3 days, 16 hours, 50 minutes
port-group Show port-group
SPZSWFLR10#show hw-module module 5 po
SPZSWFLR10#show hw-module module 5 port-group
Module Port-group Active Inactive
5 1 Te5/1 Gi5/3-4
5 2 Te5/2,Gi5/5-6
SPZSWFLR10#show hw-module module 6 port-group
6 1 Te6/1 Gi6/3-4
6 2 Te6/2,Gi6/5-6
Thanks.
5 Replies 5
Leo Laohoo
Nope.  Only 24 Gbps per slot.
Hello Leo,
Yes, there are 24gb per slot, but my doubt is if I connect both sup6-e x2 10gb in a NX5K totalizing 40gb.
4510R-e                                       NX5K
te5/1-------------------------tex/y
te5/2-------------------------tex/y
te6/1-------------------------tex/y
te6/2-------------------------tex/y
Assuming you put 5/1, 5/1, 6/1 and 6/2 in one Portchannel. A flow is only going to use one link at a time (10Gig). So, it is 4x10 but you can't call it a 40Gig interface..
Hello Reza,
Yes, it is a Port Channel. All the interface in Po10, for example. You said that I can´t reach 40Gb in this Po10... Is it right? and How much can I reach in this Po10?
A flow can only use one of the 10Gig interfaces at a time. If for example, you are transferring a 100Gig file from one device to another, that flow uses only one of the 10Gig interfaces.  But say you have 4 flows from 4 different sources, one flow uses interface 5/1, second flow 5/2, third flow 6/1 and so on.  So, its 4 10Gigs.
