CAD file for Quad Cam mount
Cookie1987
Hi all,
I am looking for the CAD file showing the quad cam mount.
I am looking for this because I am trying to work out what solution I can use to mount the quad cam to the screen rather than wall mount it.
I am designing a dual 86" LG screens with quad cam and codec pro. I
I am thinking of using the Chief LTM1U wall mount, 1 for each display with FCAV1U put out service arms. Then have a FCK016 which will connect to the mounts together, and then use a FCA840 which will sit on the poles between the displays and then connect the quad cam mount to the FCA840 and slot in the quad cam.
https://www.legrandav.com/products/chief/accessories/display/fusion/fck/fck016
https://www.legrandav.com/products/chief/accessories/display/speaker_adapters/fca8xx_speaker_adapters/fca840
https://www.legrandav.com/products/chief/accessories/display/fusion/fcav1u/fcav1u
https://www.legrandav.com/products/chief/mounts/display/wall-tilting/fusion_wall-tilt/ltm1u
Unless someone has a better idea, please help
The reason for wanting to screen mount the quad cam is because it will sit too far behind the display and I would like to have the quad cam and display flush with each other.
0 Replies 0
