01-27-2023 04:27 AM
-Trying to console back into a 4451 Router using Putty
-Worked yesterday with same computer and cable
-tried different micro usb cables and different computers to console in and they also don't work
-confirmed proper COM port in device manager
-have restarted router
Consoling DOES work with the rollover/rj45 cables, so the line con 0 is accurate
-verified baud rate is 9600.
HELP.
01-27-2023 04:40 AM
is that not worked or working, the question bit confusing for us.
so the issue with Micro USB cable ? have you installed Drivers for Cisco USB ?
01-27-2023 04:00 PM
RMA the router.
