Power Specification Tables
tdbuzz123
I noticed that for the  Cisco Catalyst 3560 Series switch that these two tables are found in the specifications at:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-series-switches/product_data_sheet09186a00801f3d7d.html
  'Measured 100% throughput power consumption'
  'Measured 5% throughput power consumption'
I expect that 100% means that the device is fully utilized with data being pushed thru every port 100% of the time.
Does the 'Measured 5%...' title imply that on average the switch will most likely be running at 5% of it's full capacity?
0 Replies 0
