Python
KathleenDelosSantos38952
Frequent Visitor
Frequent Visitor
I would like to know why my output for installed libraries is lesser than the output in DevNet course.
2 Accepted Solutions
Sergiu.Daniluk
It looks like you didn't installed the modules listed in the requirements. Or you are in the incorrect venv.
First, install the requirement:
pip install -r requirements.txt
Note: make sure you are in the dir where the requirements.txt file is located, or specify the full path to it.
Stay safe,
Sergiu
Yep. As you can see in the output, you receive an error.
The reason is because ansible does not run on windows. I would suggest to use the WSL (Windows Subsystem for Linux). It's an easy approach. I use it as well on my windows PC and works perfect.
Here is how you can set up ubuntu on WSL: https://linuxhint.com/install_ubuntu_windows_10_wsl/
Cheers,
Sergiu
Sergiu.Daniluk
Stay safe,
Sergiu
I've already installed the latest pip. Here are the last lines when I run the command 'pip install -r requirements.txt'.
Cheers,
Sergiu
Frequent Visitor
Frequent Visitor
